Calling on JDM front DC2'ers...
Where do you guys buy your replacement bulbs for your headlights? I have two blown lights, the yellow one, and the actual white one, and I'm not sure where to pick these up. Thanks.
have not had anything to blow out on me yet...so i cant help you
bump free bump cause it might be nice to know...
and by white light do you mean the little city light?
On the yellow foglights I would say buy the password bulbs or the Lumincs (sp?). As for the "white" ones I dont know if you are talking about the city lights or the headlights but I blew a headlight and i replaced it with a 05 s2k hid ($145). the city light i would say take out and take it to autozone or advance and see if you can find one like it! I sure know I have to do that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch-N-si »</TD></TR><TR><TD CLASS="quote">
and by white light do you mean the little city light?</TD></TR></TABLE>
i think so, mine came white too....take the old bulbs out and go to your local auto parts store... for the yellow fog i am not sure
f*ck it, for the yellow ones just go to Checker or something and get the Sylvania. No matter what the color of that bulb it is not going to effect it because of the yellow lens. Headlights? get some Raybrigs or whatevs
the projector ones you can buy at kragen(sylvania)9006
and the fog lights i think password jdm has it..
check your fuse fist to see if thats the problem
the fog light bulbs are regular H3's you can buy anywhere, kragen, auto plus, pep boys, ect.
it's not the bulb that makes the color yellow, but a built in cap in the headlight itself.
low beam > 9006
high beam > 9007
fog> H3
city > is regular peanut/wedge bulb 194
corner > is a regular dual-filament, i believe it's an 1157
BUT you might wanna check ur wiring, connections, and fuses first.
Modified by BlUeDC2nEr at 7:26 AM 10/26/2006
low beam > 9006
high beam > 9007
fog> H3
Well I took the projector light out and here's what I got:
I was a bit confused because I thought the bulb itself would come out, instead of the entire piece.
Big thanks to all of those who have offered help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtpktz. »</TD></TR><TR><TD CLASS="quote">
Here's what I'm talking about. What do you replace the projectors with?</TD></TR></TABLE>
that happened to me before on my Old teg with my Fog lights + Corner lights + city lights.. checked bulbs and wanst it.. found out it wasnt the bulb but the wiriing.. ghetto rigged it by tappin into the passenger side and ran it to driver side and everything came out perfect lol. now no more ghetto **** with my current car though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM DC4 Jesse »</TD></TR><TR><TD CLASS="quote">that happened to me before on my Old teg with my Fog lights + Corner lights + city lights.. checked bulbs and wanst it.. found out it wasnt the bulb but the wiriing.. ghetto rigged it by tappin into the passenger side and ran it to driver side and everything came out perfect lol. now no more ghetto **** with my current car though
lol I think I found the problem. The wire that leads to the projector had become a little unwrapped, hopefully some electrical tape will do the trick. Now the foglight, thats a different story heh.
</TD></TR></TABLE>lol I think I found the problem. The wire that leads to the projector had become a little unwrapped, hopefully some electrical tape will do the trick. Now the foglight, thats a different story heh.
The foglights are regular halogen H3's, theres millions of them on ebay and in any auto shop, just buy a regular H3 bulb (the cheapest you can find) and stick it in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtpktz. »</TD></TR><TR><TD CLASS="quote">Well I took the projector light out and here's what I got:
That IS the bulb your holding in your hand, its all one piece, the glass part doesnt come apart from the plastic bit, its a 9006 bulb, the same bulb all G3 integras use for the low beams no matter what front the car has!
</TD></TR></TABLE>That IS the bulb your holding in your hand, its all one piece, the glass part doesnt come apart from the plastic bit, its a 9006 bulb, the same bulb all G3 integras use for the low beams no matter what front the car has!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer »</TD></TR><TR><TD CLASS="quote">The foglights are regular halogen H3's, theres millions of them on ebay and in any auto shop, just buy a regular H3 bulb (the cheapest you can find) and stick it in.
That IS the bulb your holding in your hand, its all one piece, the glass part doesnt come apart from the plastic bit, its a 9006 bulb, the same bulb all G3 integras use for the low beams no matter what front the car has!</TD></TR></TABLE>
Interesting, I was expecting to find a bulb similar to the 96-00 civics (I had an 99 SI)
Thanks for the info though.
Well, turns out its not the bulbs (as I just swapped the passenger side one with the driver side one and it still did not work.)
I did however find a fraid wire leading to that light as I said in a previous post, but when I put it back together with my fingers the light still does not seem to want to come on.
hate to bring this back from the dead but does anyone know a way to remove that yellow cap for the fogs on the jdm front end? im assuming if you bake the light and pop the lens off you can get to it but i want to see if it can even be removed before i bake the lights
amej8
38
May 3, 2006 03:27 PM
utensil
Jun 17, 2001 05:13 AM
