Lighting HID/Xenon kits, Retrofits and Associated Topics
is it the bulb or my wiring?
Old Nov 6, 2007 | 09:01 PM
CeoStatus0's Avatar
Default is it the bulb or my wiring?
I just put in my SiR headlights.. and wired up my city lights... so I transfer the bulbs from my old headlights to the SiR headlights.. and one side seems to be fine and the other side is not so good..
is one bulb going bad or did i mess up in wiring somewhere?
the bulbs are at least 6 to 7 years old... Raybrigs... i lost the box for them.. i'd pick up the same pair if i knew which ones they were....
you can see how one side looks under powerd
problem solved
bad side
good side
Modified by CeoStatus0 at 12:05 AM 11/9/2007
Old Nov 7, 2007 | 10:39 AM
Si_chRis's Avatar
Default Re: is it the bulb or my wiring? (CeoStatus0)
Did you wire your city lights to the parking/signal light?
Old Nov 7, 2007 | 01:00 PM
Padawan's Avatar
Darth ModerVader
Try switching the "good" bulb to the other side. If it works fine, then you know it's the bulb. If not, it's the wiring.
Old Nov 7, 2007 | 08:27 PM
CeoStatus0's Avatar
Default Re: is it the bulb or my wiring? (Si_chRis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si_chRis &raquo;</TD></TR><TR><TD CLASS="quote">Did you wire your city lights to the parking/signal light?</TD></TR></TABLE>
yes
Old Nov 8, 2007 | 08:09 PM
CeoStatus0's Avatar
Default Re: is it the bulb or my wiring? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Try switching the "good" bulb to the other side. If it works fine, then you know it's the bulb. If not, it's the wiring. </TD></TR></TABLE>
i switch bulbs... and the good bulb is dose not light up full power on the bad side.... but I can'r figuew out what the wiring issue is
Old Nov 8, 2007 | 08:56 PM
CarbonizedDX's Avatar
it sounds like you've got a bad headlight plug and or a bad ground, I'd check your plug to see what condition it is as well as the wiring coming out of it....
Old Nov 8, 2007 | 10:07 PM
CeoStatus0's Avatar
Default Re: is it the bulb or my wiring? (CarbonizedDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonizedDX &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like you've got a bad headlight plug and or a bad ground, I'd check your plug to see what condition it is as well as the wiring coming out of it....</TD></TR></TABLE>
i figured it out.. it was the wiring for the city lights on that bad side
GetEfdupEH
Lighting
Sep 3, 2009 05:15 AM
99CivicSiBrian
May 15, 2006 06:14 PM
boosh
Apr 15, 2004 06:06 AM
SqueezinEF
11
Jul 19, 2002 09:39 PM
