Lighting HID/Xenon kits, Retrofits and Associated Topics
95 ex coupe headlight not working
Old Jun 3, 2009 | 11:46 AM
flipside1212's Avatar
Default 95 ex coupe headlight not working
Ok so today i want to get some hids from a buddy and when i got them his plug was messed up and had 2 plugs to plug into the factory headlight plug. Well i think i put the plugs backwards. So now my headlight does not work. I check the fuses and i have power at the lowbeam fuse but not he highbeam. I dont have power at the plug tho. Anyone know what this may be?
Old Jun 3, 2009 | 12:00 PM
Default Re: 95 ex coupe headlight not working
bump
Old Jun 3, 2009 | 12:39 PM
98civdx's Avatar
Master Detailer
im confused.. civics only have 1 plug for the head light. 1 on each side. not seperate.
take a picture what you saying kinda makes sense but kinda doesnt.
Old Jun 3, 2009 | 12:42 PM
the plugs from the hids had the plug missing so it had a plug on the pos. and a plug on the neg wires. i believe i put the neg wire into the power and power into the neg. these did not have highs so no wire to the top,
Old Jun 3, 2009 | 12:43 PM
bascially i think i shorted something when i put neg to pos and pos to neg.
Old Jun 3, 2009 | 12:47 PM
98civdx's Avatar
Master Detailer
it would have blown the fuse the second you turned them on check that.
ok my hids have a ballast with 1 wire going to the bulb and the bulb has a wire going to the oem socket and a wire doing to the ballest,,, that is a h4 kit and that how yours should be. check the headlight relay under the hood, then check the 4 underdash fuses 1 each light HI/LO
please take a pic its confusing me....
Old Jun 3, 2009 | 01:25 PM
i dont have the hids cuz i thought it was a blown ballest. from the oem plug to your ballest there are 2 or 3 wires depending on if you have just low hids or low/high. well the plug from the ballest didnt have the plu g it had broke and only had the pos and neg wires from it. the fuses werent blown either under the dash and under the hood. im thinkin i may have messed up the oem plug.
Old Jun 3, 2009 | 01:44 PM
98civdx's Avatar
Master Detailer
well if it was the ballast that didnt have the plug then just get a new kit.
put another set of lights in and see if that works....
did you cut the wires on the car harness?
Korean Zombie
Oct 10, 2011 02:38 PM
dabeast111
Jun 5, 2011 08:43 PM
KILLAB17VTEC
Dec 16, 2008 01:08 PM
hondaeg8
11
Jul 29, 2004 10:37 PM
