Lighting HID/Xenon kits, Retrofits and Associated Topics
80watt ok??
Old Nov 12, 2007 | 08:01 PM
joeym415's Avatar
Default 80watt ok??
i have an 05 civic sedan and im planning to get xenon 8000k bulbs that are 80W. so i was wondering if that would be too much for the stock ballast to handle. They also have one thats 55W, does that mean it wont be as bright though?
Old Nov 12, 2007 | 08:05 PM
bpr0422's Avatar
Default Re: 80watt ok?? (joeym415)
the 2005 Civic has halogen bulbs... not xenon hid bulbs.... (USA...) dunno about Canada or other parts of the world... tho the jdm civic might have hids...
Your civic uses the 9006/9003 two bulb setup.
Those bulbs are not recommended to be replaced with higher wattage bulbs, because the contact surface area is small that it can create a lot of heat - or so i have read
You risk the chance of melting the plug and the harness by swapping in higher wattage bulbs.
The higher the wattage, the greater the draw of amps, and the brighter the halogen bulb... and more heat is created.
Tho you should go check out Philips X-Treme or Sylvania Silverstar ULTRA, since the philips are harder to come by in your size...
Old Nov 12, 2007 | 08:11 PM
joeym415's Avatar
Default Re: 80watt ok?? (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">the 2005 Civic has halogen bulbs... not xenon hid bulbs.... (USA...) dunno about Canada or other parts of the world... tho the jdm civic might have hids...</TD></TR></TABLE>
sorry i meant xenon halogen, well at least thats wut it says on this site http://www.texonstore.com/serv...etail. so i guess ill go with the 55W. lower wattage doesnt necessarily mean its not as bright right?
Old Nov 12, 2007 | 08:14 PM
joeym415's Avatar
im lookin for something thats white with just a hint of blue
Old Nov 12, 2007 | 08:45 PM
bpr0422's Avatar
Default Re: (joeym415)
See if these bulbs come in your size...
https://honda-tech.com/zerothread/1888068
https://honda-tech.com/zerothread/2139371
Old Nov 12, 2007 | 09:04 PM
joeym415's Avatar
Default Re: (bpr0422)
i previously had had a pair of wagner truview. i accidently busted one of the bulbs so im deciding whether i should jus buy a single or get a new pair. wuts ur opinion on the truview?
Old Nov 13, 2007 | 07:28 AM
Padawan's Avatar
Darth ModerVader
If your car uses 9006 bulbs, pick up a pair of HIR 9012's. You won't find a better performing bulb for the price.
backinblue92
Lighting
11
Dec 11, 2015 07:38 AM
delsolo95
Mar 7, 2013 12:44 PM
NY's_Freshest
Lighting
Jan 28, 2012 02:24 PM
dc4drewH
Jul 12, 2004 09:38 PM
mickey513
Mar 3, 2003 09:20 PM
