Lighting HID/Xenon kits, Retrofits and Associated Topics
04 civic headlight... Need help
Old Dec 8, 2007 | 02:10 PM
SavB18's Avatar
Default 04 civic headlight... Need help
I want to black house my headlights, but i dunno if the lights need to be cut open or baked open. Can someone please let me know or direct me to a DIY.
Thanks
Old Dec 9, 2007 | 02:03 AM
lalo's Avatar
Default Re: 04 civic headlight... Need help (SavB18)
EBAY HAS THEM
Old Dec 10, 2007 | 11:00 AM
chawski's Avatar
preheat your oven to 250, turn off the oven, and let them sit for 4-5 minutes. after that, gently pry the lense off with a flathead screwdriver. i have found that butyl window sealer works great to seal back up. to properly seal, lay a bead of the window seal around the plastic where there will still be some original adhesive. warm this up for a minute or 2 in the oven (again off, but preheated to about 250). put the lense on and get it pretty close to in place. put back in the oven for another 2-3 minutes and then push the lense on the rest of the way. Then, wrap the lense in newspaper or something and wrap that tightly with tape until cool. I found that hockey sock tape works real well for this because it stretches, so you get a real tight fit. hope this helps. lemme know if you have any more questions or if something doesnt make sense
Old Dec 13, 2007 | 01:09 PM
Mirakle's Avatar
Default Re: (chawski)
Is this method will work on any kind of head light? Well Thank you for your suggestion.
I will go and try it by myself.
Old Dec 16, 2007 | 08:20 PM
prelude1897's Avatar
Default Re: (Mirakle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mirakle &raquo;</TD></TR><TR><TD CLASS="quote">
I will go and try it by myself. </TD></TR></TABLE>
Yep yep, the oven method works on most headlidghts, not all, but most
Old Dec 17, 2007 | 12:12 PM
ES1_TopGun's Avatar
Default Re: (prelude1897)
THIS IS FOR A DIRECT DIY FOR THE 04-05 CIVIC
http://www.civicforums.com/for....html
DJDriver88
Jun 27, 2012 11:16 AM
dso
Acura TL, RL & ZDX
May 26, 2009 10:08 PM
stevew84
Apr 10, 2008 09:23 AM
I Like Hondas
Jul 5, 2006 11:16 AM
LOWLIFEHATCH
Apr 5, 2003 06:50 PM
