tensioner reset
Old Mar 2, 2016 | 08:39 PM
h20ham's Avatar
Default tensioner reset
Good day
Had an issue with my motor
Before I could get the used motor I tried a timing chain kit
The engine is hooped. Got my used motor and am in the process of transferring known good parts, new water pump etc to the used block.
How do I reset the hydraulic tensioner. It seems by lowering the arm which disengages the locking teeth?
Thanks
James
Old Mar 2, 2016 | 08:45 PM
kr3w108's Avatar
Default Re: tensioner reset
You must hold the locking arm back as you push the piston into the tensioner body. IF the motor is still together all you do is turn the motor backwards untill the tap lines up with the hole on the side, then you put in a thumb tack or paperclip to hold it.
Old Mar 2, 2016 | 08:51 PM
h20ham's Avatar
Thanks
It worked
Kind Regards
Old Mar 2, 2016 | 09:32 PM
kr3w108's Avatar
Originally Posted by h20ham
Thanks
It worked
Kind Regards
No problem
semse2
24
Jul 22, 2020 05:41 AM
justaman
Jul 11, 2016 03:38 AM
hybrids2k
Jan 26, 2009 12:38 PM
BigZ88
55
May 3, 2003 10:23 PM
