kpro for k20a2 94 ej ?
Old Apr 20, 2015 | 09:02 PM
EGhachiback's Avatar
Default kpro for k20a2 94 ej ?
Hello ht, hopefully this post is in the right spot. Like title states I have a 94 ex civic coupe with a k20a2 swap. I'm looking to get kpro, and I was wondering what would work for my setup. I'm looking to get something second hand because its a cheaper alternative. I have a PRC (jdm type r) ecu currently. I'm unsure of the year for my motor, also I'm using a jumper harness.
thanks
Old Apr 21, 2015 | 06:10 PM
GoldieWang's Avatar
10 Year Member
Default Re: kpro for k20a2 94 ej ?
which engine harness do you have and which dash swap harness do you have? Some ecus require a jumper to work with a different ecu which is what I assume you ment by jumper. But you just have to send your ecu in to hondata and tell them which one it is or if you buy a used one make sure it works with your engine and engine harness
SuperDan222
Nov 30, 2013 03:18 PM
veekster87
Aug 21, 2010 12:16 PM
jlfrnce
Mar 22, 2007 04:57 PM
Camshaft
Jul 31, 2004 10:41 PM
Phoenix GSR
Mar 12, 2002 11:45 PM
