K24 in ek
Old Jan 10, 2013 | 08:15 AM
Ek4Daphatch's Avatar
Default K24 in ek
Wats up hondatech I'm running a k24 in my ek with ekk2 and I'm having problems closing the hood the only solution seems to be that I need good spacers but really hate the way they look has anyone else came across this problem or have any ideas that I can try? Thanks
Old Jan 16, 2013 | 08:08 AM
Default Re: K24 in ek
Thanks for the help everyone! 99 views n no responses -_-
Old Jan 16, 2013 | 08:11 PM
stayontrack's Avatar
i think you need to cut the hood skeleton. what exactly is hitting the hood?
Old Jan 16, 2013 | 08:28 PM
doood's Avatar
been there done that
which holes in the mounts are you using?
Old Jan 17, 2013 | 07:41 AM
gawith00Si's Avatar
We just re-drilled the holes for mine and moved the motor back a little more. We still had to cut some of the webbing.
gawith00Si's Avatar
What brand of mounts do you have?
Old Jan 17, 2013 | 07:43 AM
gawith00Si's Avatar
We noticed that Innovative tends to keep the motor up higher. But my installer just re-drilled the mounts.
Old Jan 17, 2013 | 12:14 PM
doood's Avatar
Innovatives suck. Hasports have much better positioning.
Old Jan 18, 2013 | 08:01 AM
I'm using hasport mounts n I did cup out the skeleton it was hitting the throttle body n the left corner of the valve cover
Old Jan 18, 2013 | 05:13 PM
doood's Avatar
Old Jan 22, 2013 | 09:29 AM
t.schultz's Avatar
I would say your best bet is to run a spacer on the mount or the hood...
Trung Nguyen
18
Jun 15, 2010 02:29 PM
drtysohc
Nov 22, 2006 09:30 AM
_unknown_
Feb 19, 2002 08:33 AM
