K20A vs K20Z1?
Old 08-22-2013, 09:34 AM
jdmpro23's Avatar
Icon2 K20A vs K20Z1?
Is there really any difference between a K20A vs K20Z1 other than LSD and slightly different HP increase. Just want to know if it's really worth spending the extra $$$ for the Type R.
Old 08-22-2013, 09:50 AM
been there done that
doood's Avatar
Default Re: K20A vs K20Z1?
do a k24 instead
Old 08-22-2013, 11:16 AM
Mike@K-Tuned's Avatar
The K20A has shorter 4, 5 and 6 gears.
It has 11:5 comp pistons compared to the 11:0 K20Z1
K20A also has an LSD and a slightly different intake manifold.
Old 08-22-2013, 12:35 PM
jdmpro23's Avatar
Thanks for the info guys. I'm just trying to make it a reliable and quick setup.
Old 08-22-2013, 04:10 PM
J-RAD's Avatar
-either way, you're going to need the k20a2 harness
-if the k20a comes with an ECU, it will make dropping the motor in easier, since the k20a ecu does not have an immobilizer
-the k20z1 transmission has a different type of speed sensor. need a converter for that
both are great motors. whichever you can get your hands on easier and cheaper would be best. good luck!
Old 09-26-2013, 01:14 PM
mazharracer's Avatar
get k24 more torque
BMRALR
14
11-03-2007 05:27 AM
psegs80
21
10-16-2007 10:03 AM
CTRwannaB
04-30-2004 03:17 PM
sackdz
07-03-2002 12:53 PM
comptechgsr
10-14-2001 07:16 PM
Quick Reply: K20A vs K20Z1?
