FS: K Motor Parts ONLY
#101
Re: FS: K Motor Parts ONLY
i have an 02 k20a2 engine harness/charge harness, and TB for sale or trade. make offer/trades? can provide pics for anyone interested
EDIT: TB sold, harness still available. complete head might be for sale soon, if my short block sells this weekend. Make offer on head if interested. engine has under 80k, engine still in car, runs perfect. located in norcal
#105
Item: Built k24a4
Price: 1100 obo
Item Description: K24a4 block for sale. Je 13:1 comp pistons, blueprint rods. includes side cover/oil pump/chain/oil pan. Made 245whp with stock tsx head and cams. Burns a little oil but still makes good power.
Photos:
AEM EMS Part number :1030 Used $980 obo
http://www.google.com/url?sa=t&sourc...lzEcT4dTAHlxSA
Block is currently bored to 89mm. Block is in perfect shape and will work perfectly for anyone trying to build a big bore motor. $900 obo
Contact: text me 3055052395 or pm me
Item Description: All prices are obo
Photos:[B] All parts are new except when noted.
CP custom pistons. Designed to be used in a 2.0L deck height motor with a k24 crank. Wrist pin is located upwards to allow use of a stock length 2.0 rod.Depending on your combination these pistons are in the 14:1 compression range and are designed for plenty of clearance for big valve/cams.They come with rings/pins/support rails. $800 obo
Brand new K24 crank $250 obo
AEM EMS Part number :1030 Used $950 obo
Circuitworx hubs. Brand new. Designed to use a 36mm outer axle joint. so you k swap guys can use the unmodified factory type s axles and keep the 4 lug. comes with extended arp studs. $300
K series alternator, used in good shape works perfectly. $100
ITR cluster $125
PWR EG radiator $250 obo Used but in great shape. One of the best quality radiators you can buy.
Fuel injector clinic 775cc high imp injectors. Used. perfect for a e85 setup. $300 obo
Factory lower gasket kit. $30.00 .comes with front/rear main seals/vtec solenoid seal and other seals required for the timing chain side cover.
Factory k24 headgasket $50 factory k series exhaust manifold gasket $10
Price: 1100 obo
Photos:
ITR cluster $125
#106
Up for sale K-series 62mm Magnesium Kinsler ITB's $1,900 picked up in Hesperia Ca. shipping is available at buyers expense. fuel rail was powered coated gloss black. TOP FEED, INJECTORS & THROTTLE CABLE ARE NOT INCLUDED. PM with questions. serious inquires only please. i will give specs to potential buyers.
BUMP IF VIEWED PLEASE!
#109
I have a Brand New R Crew replica header it's a 4-2-1 design. It's for K series swapped motors. This is the same one that Private label sells for $450 plus shipping on their site.
Price:$350 shipped
Means of contact: PM/ Thread/ Email
Price:$350 shipped
#111
I have a set of DC5R ITR cams. Dont know what they go for so make me an offer. the cams are in really really good shape. PM me with questions.
Located in Socal
Located in Socal
#112
WTB: LMAs lost motion assembly ... lma springs
#115
Testing the waters: Brand new in the oem sealed packaging ITR 4th, 5th, & 6th gears (both countershaft & mainshaft gears) these gears are specific to 01-05 ITR gear boxes & are sought after by many race teams. asking $835 shipped OBO
let me know if you are interested
fyi
ITR k20a 01-05
4 = 1.212
5 = 0.972
6 = 0.78
RSX-S k20a2
4 = 1.147
5 = 0.921
6 = 0.738
RSX-S k20z1
4 = 1.147
5 = 0.921
6 = 0.738
si k20z3
4 = 1.147
5 = 0.921
6 = 0.659
tsx k24a2
4 = 1.028
5 = 0.825
6 = 0.659
fyi
ITR k20a 01-05
4 = 1.212
5 = 0.972
6 = 0.78
RSX-S k20a2
4 = 1.147
5 = 0.921
6 = 0.738
RSX-S k20z1
4 = 1.147
5 = 0.921
6 = 0.738
si k20z3
4 = 1.147
5 = 0.921
6 = 0.659
tsx k24a2
4 = 1.028
5 = 0.825
6 = 0.659
#118
i have a k20a2 engine harness complete minus injector clips. but i have RC 440cc injectors and clips that can make this harness complete. asking $300 shipped. for everything
[/QUOTE]
K20 halfshaft $120 shipped.
K20 Charge Harness $120 shipped
K20A2 Type S TB Complete with Sensors $175 shipped
[/QUOTE]
#120
brand new p2r tb adapter $40
Ep3 pulley - complete, used in good shape $50
k20a2 Alt with 68k miles $50
ktuned heater core block off plug $15
#121
K20a2 head fs/ft. came out of running car, engine have around 80k. Was going to build frank motor but couldn't find block for right price. Asking 700 obo
Or
K24a2 long block came out of rear ended (05)tsx with around 40k. Was told engine ran perfect with no issues. Asking 1500 obo
Will take pics later, or pm me with your email.
If head sells I will probably keep longblock, if long block sells first I'll keep head.
Parts located in norcal/sacramento area.
Prefer pick ups, but can ship if buyer pays shipping.
Or
#122
anybody looking for stock rsx-s internals? i bought a longblock and sold the head and sold the bare block, keeping the pump and pan. selling the stock crank, rods, pistons if anybody want them.not sure what to sell for so make offer, cash or parts for trades welcomed.
#123
Kill Gil
FS: I have two brand new Skunk2 74mm K-Series Throttle bodies. These are the latest versions and have zero issues. They are brand new and never been used. They come complete with brand new mounting hardware. Retail price is $419 + tax & shipping
Only asking $310 shipped USPS prioirty with delivery confirmation.
actual pics
Skunk2 is proud to introduce its all-new, 74mm Pro Series Throttle Body for Honda's K-series engines — the biggest K-series throttle body you can buy. Skunk2's Pro Series Throttle Bodies are designed to be used with OEM Acura RSX (PRB) or Skunk2 Pro Series Intake Manifolds for bolt-on horsepower and torque gains by optimizing engine airflow (other applications, including '06+ Civic Si RBC manifolds, require adapter plate).
Skunk2 throttle bodies undergo an extensive design and testing process to produce a unit that doesn't just provide more flow, but retains smooth drivability and OEM throttle characteristics. Skunk2 Pro-Series Throttle Bodies are designed using the latest CAE (Computer Aided Engineering) tools to produce a unit that exceeds industry standards. Each Pro-Series Throttle Body is CNC-machined from forged, billet 6061-T6 aluminum and hard anodized for durability in Skunk2's signature Black Series finish. Additionally, Skunk2's unique K-series throttle pulley design allows for smooth movement and pedal modulation, and the OEM coolant hoses have been eliminated for cooler operation.
A larger throttle body is key to producing additional power throughout the powerband on modified engines with increased airflow demands. Skunk2's new Pro Series Throttle Bodies feature a 74mm bore, which results in significant horsepower gains throughout the powerband on naturally aspirated applications and even more on forced induction ones.
FEATURES:
■Large 74mm Bore
■Compatible With OEM Throttle Cable
■CNC-Forged 6061-T6 Billet Aluminum Construction
■Sealed Bearings For Smooth Operation
■Durable, Corrosion-Resistant Hard-Anodized Finish
■Eliminates OEM Water lines For Cooler Operation■Integrated Skunk2 Badge
actual pics
FEATURES:
■Large 74mm Bore
#125
WTB K24:
water pump housing, chain case, crank key, crank bolt, crank pulley, knock sensor, and oil pressure sensor
the block i have is a k24a4 if that even matters
