Pops and bangs but won't start
Old Oct 8, 2025 | 03:09 PM
Gunnny's Avatar
Default Pops and bangs but won't start
Hi I have a Honda civic 1.6i VTec se executive hatchback automatic d16v1 mrk7, just broke a stud on my engine mounting bracket ended up getting a replacement bracket replaced it put everything back together then realised my silly buddy who was helping me out left my electrics running which totally drain my battery out so couldn't start car.. Then I manage to get some jump leads to try and jump start it but it won't start all I was getting was pops and bangs like it wants to turn and start but nothing it won't start and just makes pops and bangs whilst trying to start can anyone help me diagnose the problem could it just be that my battery is knack and not enough juice to run the fuel pump for it to send fuel to start or have I not the timing out by replacing bracket etc please help me??
Old Oct 8, 2025 | 07:31 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Pops and bangs but won't start
Check your spark plug firing order.
Old Oct 9, 2025 | 03:50 AM
Gunnny's Avatar
Thanks for your reply.. Can please explain what you mean by spark plug firing order..
Old Oct 9, 2025 | 08:15 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Looking at your distributor cap from the right side fender: Spark plugs are numbered from one to four beginning at the cam gear and moving toward the distributor. Beginning at the top left position on the distributor cap and moving CLOCKWISE, the plug wires connect in the firing order - one, three, four, and two.
Old Oct 11, 2025 | 02:25 PM
Gunnny's Avatar
Managed to sort it yesterday it turn out I bent a pin on my tdc sensor whilst plugging cable back in had to strip it out and straighten the pin and now she back up and running sweet.. Thank you so much for you advice I did check the order on my plugs all was good had the sparkugs replaced too as they been in there for over two years as I only use denso iridium
dragaholic
Feb 22, 2024 08:03 PM
TZ33PPY
Honda Motorcycles
Sep 22, 2022 01:15 PM
97hatch904
Aug 31, 2015 04:38 PM
hamburgler
Aug 21, 2011 07:57 AM
SiRidiculous
Jan 18, 2005 01:26 PM
