Noob!
Old May 17, 2020 | 07:12 AM
RicerEJ6's Avatar
Default Noob!
I'm here for the chicks 😂😂😂🤷‍♂️. Ok maybe not. Just introducing myself. This is a current list of my build. Her names Olivia (looks like an olive) and she's a 96 Civic Hatch CX
Engine
2006 k24a
Hondata Kpro V4
RBC Intake manifold
Intake Manifold thermo gasket
K-Tuned 70mm Throttle body
K-Tuned black fuel rail
K-Tuned liquid fuel gauge
K-Tuned fuel pressure regulator
6an feed & return from pump to rail
K-Tuned ep3 idler pulley kit
K-Tuned evap plug
K-Tuned map plug
K-Tuned idle assist delete
K-Tuned heater delete plug
K-Tuned swivel neck
K-Tuned upper coolant housing
K-Tuned Pass Radiator setup
SPAL high performance fan
EKK2 Hasport Motor mounts
Wireworx charge harness
Wireworx ground kit
Hybrid Racing subharness
VR1Racing oil
Humble Performance tuned on E85
Transmission:
2004 Rsx Type S 6spd
MFactory LSD
Synchrotech Master Rebuild Kit:
1-6 Pro Series Carbon Synchro set
1-6 springs 1-6 harden sleeves
4 shaft bearings, 2 axle seals, input shaft seal,shift rod seal, bearing clip all oem
Oem throw out bearing
Competition Stage 4 clutch kit
Competition 11lb flywheel
Oem rear main seal
Speedfactory detent springs
Speedfactory shift selector springs
Driveshop swap axles
K-Tuned Race Cables with billet bracket
K-Tuned Billet shifter box
K-Tuned billet shifter plate
S2000 clutch master cylinder
Steel braided clutch line
Synchromesh trans fluid
Turbo kit:
Full-Race Twin scroll T4 manifold
Precision 6266 Turbo
Tial 44mm wastegates (2)
Tial 50mm bov
Treadstone 1000hp intercooler
Deastchwerks 1000cc injectors
K-Tuned 4bar map sensor
Custom 3" piping hot & cold side
T-bolt clamps
3" downpipe to 3" exhaust piping V-band
3" vibrant performance muffler
Wastegate dumps facing to floor
K-Tuned oil pressure adapter
Vibrant 3an oil feed line
10an return line
Vibrant vacuum block
Push lock fittings & poly tubing
MAC boost by gear 3 port
Suspension/Brakes:
Enkei RPF1 16x7 wheels
2255016 Potenza RE71r front tires
2054516 Continental rear tires
ARP extended front studs
Blox Drag series coilovers for
the track/ Progress CS2 550 front 450
rear for the street
Blox Pro series front camber kit
K-Tuned Traction bar with 150lb weight plate
K-Tuned Compliance bushing
Skunk2 front lower control arms
Crossed drilled slotted rotors front and back
Powder coated red calipers
Steel braided brake lines
EG subframe & rack
New inner and outter tie rods
New oem rack bushings
Rear OEM sway bar with Precision
links and JDM subframe brace
Interior/exterior:
Lexus sage green paint
2000 front end
2000 rear tail lights
Carbon fiber hood painted same color
CWB Drag wing
New ctr rep headlights
Oem em1 front grill (needs paint)
Em1 lip
Ctr rear lip
Black s2000 seats
Nrg hub & nrg quick release
Momo Monte carlo 350mm steering wheel
Carbon fiber dual gauge bezel
AEM x series boost gauge
AEM x series wideband
New OEM Carpet
New windshield with seal
dc2itr617
Northeast (Sales)
Nov 20, 2013 04:20 PM
H22swag
Oct 17, 2013 11:58 AM
H22swag
Sep 5, 2013 07:22 PM
sc34dx
Aug 5, 2012 03:56 PM
LuckyToBeBC
Aug 22, 2010 04:14 AM
