new here today and need sum help for my build
i have a b20v motor with gsr trans looking to run dyno dwn the road , what type injectors will i need and whats the best fuel setup (fuel rail , injectors , regul, etc.)
Sanji
Re: new here today and need sum help for my build
You may want to head over to the All Motor subforum here: https://honda-tech.com/forums/all-mo...-aspirated-44/
NEED HELP ..... I had p28 chipped with s300 plugged it without tune Nd drive about 5 miles nd it started tapping . NO ITS NOT BLOWN .
i may have started car than unplugged it and plugged the s300 in on accident not 100% sure.
Also ppl told me it’s not the ecu because it has nothing to do with the engine problem.
Also thought it could be the lma’s But I checked and they seem fine. If I do valve adj and replace belt (Belt could be to tight) will this fix the problem and wat parts do I need for adjustments?
B20 b16 heada
B16 head making tapping noise lam’s good could it be valves need adj ? Belt seemed a little tight to ? Also plugged ecu s300 drive 5 miles and it brgin tapping
H-T Administrator
Your description is a bit vague. "tapping" could be valves that are too tight, lost motion assemblies that are failing, an exhaust leak, or a multitude of other things. Maybe find a good local mechanic if you're not comfortable troubleshooting it yourself. Good luck
exotik4doorcivic
12-24-2006 12:49 PM
