Need Del sol wiring help
Old Mar 15, 2023 | 09:42 AM
mondo806's Avatar
Default Need Del sol wiring help
So my name is mondo im new to the forums but not new to the game ,as stated i have a 93 Del sol it does run and drive but as most old cars its seen better days and mechanics. So with that said I have a fan issue ,it works bc he hard wired it to a switch now knowing that I have replaced everything imaginable from radiator to relays fuses thermostat sensors except wiring now mechanically it runs fine and seems to be working properly but it still only runs with switch and it reads on instur.ent panel that its over heating but its not so I've started following wires n found that he cut the wires from the fuse box and now noticing even the under dash harness . So here where I need help so I've noticed that under the hoods fuse box there are two wires cut i believe they are white and blue or blue with white my question is where did they both go bc the under dash harness im only seeing one which is the one he hard wired to a switch and the battery I tried just reconnecting the one to the 2 cut ones since they are in the same fuse but nothing so I believe that they are connected to 2 different spots and im only finding one
Thomas Dyer
15
Aug 9, 2020 08:45 PM
Mimpiester
May 7, 2017 11:42 PM
london ritzler
Dec 27, 2012 03:29 PM
mo_thug_85
Jul 29, 2010 02:32 PM
hatch4raceb16
11
Mar 2, 2004 12:00 PM
