lost vtec
ok i have a 94 accord f22b1 but i lost vtec about a week ago... ive tried to clean the screen on the vtec soleniod and the little piston goes up and down freely.. checked my oil and its full even changed out the pressure switch and the top heat deal with his and still nothing... also checked and i do have power going to the pressure switch but still no vtec and it was running great but then just quit randomly... help?
Take computer out and crack the case open look for blown capacitors. Computer location is floorboard right side. You have a plate use 10mm socket and a Phillips screw driver.
i went and looked at the ecu and nothing was burnt or anything.. and also like a day before that i did run sea foam though it bc i had an idol problem the problem went away but now i have another problem and thats no vtec....
This really isnt the right place to post it. If you post it here : https://honda-tech.com/forums/honda-accord-1990-2002-2/ : you'll get all the help you need.
