Hello all!!
Old Apr 9, 2018 | 12:21 PM
Crxh22_projct's Avatar
Default Hello all!!
Hi every one new to this forum was looking for some advice on getting a h22 motor into a crx hf, have engine most of the way in can’t get it to fit all the way so mounts are in place my balancer keeps getting in the way and can’t get the engine level after tilting all the way to the tranny side any help would be appreciated thanks
Old Apr 16, 2018 | 08:18 PM
Conner's Avatar
Default Re: Hello all!!
Just pull the balancer off, if you haven't finished already. I replaced the timing belt and waterpump on my H22 before throwing it in and left the balancer and accessories off until it was fitted.
Old Apr 17, 2018 | 05:50 AM
Hey thanks Connor!
Unfortunalty I have 3 kids and very little time to play. So Up getting the engine down in there the balancer dinged off the bay slightly so hopefully that won’t cause a wobble. Then taking a cutting wheel and cutting out the wheel well slightly to allow for the balancer to sit down in there without hitting the wheel well. I’ll end up having to weld a patch in there because I had to cut into the rail slightly since I’m retarded and bought a light weight pully that has not only the alternator belt groves but one for the a/c as well which won’t be installed.
Old Apr 17, 2018 | 08:16 AM
I suppose now the biggest worry I have is wiring the hf harness to the h22 with using the h22 harness for jumpers I’ll pick up an odb0 to odb1 jumper and repin the vtec solinoid into the odb1 harness and there’s a jumper for the dizzy as well. Do I need to worry about the injectors? Or anything from the interior wiring that wouldn’t plug and play with the h22. What I find interesting also is that the alt plug on the hf harness fits into the h22 odb1 alt.
Shoukd I keep this alt or get the crx hf alt and use that on the set up? Sorry for so many questions
bb4socal
Dec 12, 2005 06:28 AM
1700anddroping
Jul 8, 2004 05:51 PM
specialedd
Jul 21, 2003 06:06 AM
AZHottie
Apr 2, 2003 09:38 PM
red92s
Dec 15, 2002 10:03 PM
