2004 CRV ABS Modulator
Old Sep 14, 2018 | 03:16 PM
rlxagn's Avatar
Default 2004 CRV ABS Modulator
The ABS Modulator has a very slight seepage. The car stops just fine, however I have to put a round 1/4 inch (or maybe a little less) break fluid in the reservoir every 7-10 days. I like to keep it at the upper mark on the reservoir. Can that Modulator o ring/gasket be replaced on the bell end as that is where it appears to be coming from. I was looking at recommended o rings if it can be replaced and I believe I need an EPR type. Does Honda make a replacement o ring/gasket? The 57110-s9a-e01 Modulator is astronomically expensive and as I understand a dealership would need to reprogram my ECU if and/or when the Modulator is replaced.
Last edited by rlxagn; Sep 14, 2018 at 03:19 PM. Reason: I needed to change an "I" to "The" just before that part number I mentioned
mikehai
Jul 9, 2017 03:04 AM
Tech-Nics
May 18, 2010 12:15 AM
cobradvm
Nov 6, 2008 04:24 AM
Fraggle
Nov 2, 2003 11:03 AM
