2000 Accord 3.0
2000 Accord 3.0
Good day mates, I recently got lucky and purchased a 00' Accord EX loaded with 68k original on it, she purrs like a big cat is clean as a babies bottom. a few issues with her front suspension getting replaced top to bottom, but she thmps a little in 2nd n 3rd gear, its an auto of course, I found out its likely the 2nd and 3rd clutch pressure sensor which sounds about right cuz she move out. the bigger issue is the lights in dash and gauges flicker and jump, I also had a power outage yesterday on the highway at about 65. After replacing the battery and installing I had a voltage spike and blew the main Batt fuse, after we corrected that all the gauges went bats, put her on an OBDII no codes except for bad connection on clutch sensor. I went to bed. Next morning, no issues started rite up like the champ she is, a little flicker in the batt and brake lights in cluster, only issue was the speedo needle past the peg, I got to work borrowed a big magnet and drug the meter back around in front of the peg, problem solved. Its running well and most everything seems to have reset to factory which is great, I just need to track that grounding or short issue now, will update soon.
Ddunnusmc
08-12-2017 05:05 PM
cambriatire
02-09-2008 12:21 PM
