Wrong Engine Mount?
Old Oct 11, 2007 | 10:58 PM
Adrian G. Aka JDMonkey's Avatar
Default Wrong Engine Mount?
i have a 98' LS engine
97' Ek hatch
I heard the only two mounts i needed were the T rear mount and the Timing belt bracket, Which i bought, i swapped the engine and it sits crooked and that caused the shift linkage to not be able to mount,
my friend realized that the reason its lower on the driver side is because i need another mount, so my question is
What mount do i need?
Its the one on the driver side that i need to replace,
Someone please let me know what mount i need!
Old Oct 12, 2007 | 06:41 AM
EG_H2B's Avatar
Default Re: Wrong Engine Mount? (Adrian G. Aka JDMonkey)
Make sure that you have a 2000 SI rear bracket and a 2000 SI post mount and you should be good.
Old Oct 12, 2007 | 11:15 AM
jdmcars.com's Avatar
Correct, with using a 00 SI rear bracket and drivers bracket, along with your Civic stock mounts you would be fine, or you can purcahse an upgrade aftermarket mount kit as well from someone such as JDMCars.com
Old Oct 12, 2007 | 06:09 PM
Default Re: Wrong Engine Mount? (jdmcars.com)
i have all the other brackets i need, even the si timing belt bracket, but my engine mount is too short?
Old Oct 13, 2007 | 10:35 AM
EG_H2B's Avatar
Then you must have the wrong bracket or mount
Old Oct 13, 2007 | 11:10 AM
Default Re: Wrong Engine Mount? (EG_H2B)
I found out its the wrong timing belt bracket, some guy on honda-tech sold me the wrong one, its not the 99-00 si, so the mount is right,
McDonagh
Sep 20, 2008 07:58 PM
McDonagh
Sep 20, 2008 05:15 PM
Scorch7
Dec 27, 2002 02:30 PM
