Wrong Engine Mount?
i have a 98' LS engine
97' Ek hatch
I heard the only two mounts i needed were the T rear mount and the Timing belt bracket, Which i bought, i swapped the engine and it sits crooked and that caused the shift linkage to not be able to mount,
my friend realized that the reason its lower on the driver side is because i need another mount, so my question is
What mount do i need?
Its the one on the driver side that i need to replace,
Someone please let me know what mount i need!
97' Ek hatch
Correct, with using a 00 SI rear bracket and drivers bracket, along with your Civic stock mounts you would be fine, or you can purcahse an upgrade aftermarket mount kit as well from someone such as JDMCars.com
I found out its the wrong timing belt bracket, some guy on honda-tech sold me the wrong one, its not the 99-00 si, so the mount is right,
