won't start!!
Old Sep 10, 2012 | 03:41 PM
kern303's Avatar
Default won't start!!
I just got done putting a 1996 JDM b18c in a 91' ef i'm converted to obd1. I'm using obd0 injectors with a brand new resistor box. I'm running a obd2 to obd1 dizzy jumper harness. I have a brand new gsr chip in my P28 ECU"installed the correct way" The motor turns over fine, i have spark. i have fuel pressure through the fuel rail. I sprayed carb cleaner in the intake manifold, and it ran for a second. i haven't wired up the vtec wires yet. Does anyone have any idea?
Old Sep 10, 2012 | 04:12 PM
4drEF's Avatar
Keyboard Humorist
Default Re: won't start!!
Since you got it to run a little on carb cleaner, then the logical answer to me is that your aren't getting fuel.
Check for power at your injectors when you have the ignition set to 'ON'. (Main relay supplies the resistor box with 12V and the resistor box sends that voltage to the injectors).
ECU sends a ground signal to fire the injectors so you will need a noid light to check to see if they are firing.
If they are not firing, then you need to verify your wiring from ECU to distributor.
Old Sep 10, 2012 | 04:28 PM
kern303's Avatar
i have 4 wires that i have to add into the ecu plug they go to A3, A7, C1, C2
Old Sep 11, 2012 | 10:23 AM
kern303's Avatar
i wired up A3 and A7 and it still won't start!
solsquad27
May 15, 2012 11:54 PM
BoostinTEG
Sep 1, 2011 06:46 AM
supra_king87
Jan 13, 2010 10:07 PM
Mr. Em1
Dec 17, 2007 09:11 PM
white90rexsi
Jun 22, 2007 06:21 PM
