Wiring vtec haveing problems!
Old Nov 11, 2003 | 08:07 PM
chero112's Avatar
Default Wiring vtec haveing problems!
I have a 95 civic EG and I just finished putting in a 95 gsr motor (B18c1) now I'm trying to wire the vtec. I all ready know were I pin them to the ECU that's all ready done I just can't seem to find or even know where the KNock sensor or the secondary Intake solenoid is I just need the exact pin point. Another question Do I need to tape the evap purge power and evap purge solenoid for vtec to work? Thanks for all your help. I will post pic's when I done.
Old Nov 11, 2003 | 09:10 PM
hondaZvic's Avatar
Default Re: Wiring vtec haveing problems! (chero112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chero112 &raquo;</TD></TR><TR><TD CLASS="quote"> I just can't seem to find or even know where the KNock sensor or the secondary Intake solenoid is I just need the exact pin point. Another question Do I need to tape the evap purge power and evap purge solenoid for vtec to work? Thanks for all your help. I will post pic's when I done. </TD></TR></TABLE>
knock should be directly on the back of the block. or do u need the pinout location on the ecu? if so, what ecu are u using?
and for the vtec, u shouldnt have to tap any power wire. it just gets a signal(blue/black) from the ecu and the other wire is a ground(black).
Old Nov 12, 2003 | 01:19 AM
chero112's Avatar
Default Re: Wiring vtec haveing problems! (hondaZvic)
hondaZvic so the knock sensor is behind the block on the driver side or on the passenger? And where is the Secondary Intake Solenoid? I'm running a P28 ECU, I already know where the pin g to on the ecu. I just can't seem to find certain wires.
Old Nov 12, 2003 | 08:50 PM
hondaZvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chero112 &raquo;</TD></TR><TR><TD CLASS="quote">hondaZvic so the knock sensor is behind the block on the driver side or on the passenger? And where is the Secondary Intake Solenoid? I'm running a P28 ECU, I already know where the pin g to on the ecu. I just can't seem to find certain wires.</TD></TR></TABLE>
-the knock is a red/yellow wire. (only 1 wire) it should be by the oil filter somewhere...
-and the secondary intake solenoid. i believe is under the intake manifold. should be connected to like a black box maybe...
-sorry, i cannot give u an exact location, because im not to familiar with the gsr (im an H22 guy, but they are all pretty similar)
where is VTECVILLAIN? isnt he the gsr/civic guru on here? IM him. maybe he can help u more than i can.
but keep us posted.
Old Nov 12, 2003 | 09:21 PM
chero112's Avatar
hondaZvic I got it done finally, That's for all your help. Oh man vtec kick's i nice and loud, thanks a lot I'll post pic's up thanks again
Old Nov 13, 2003 | 11:59 AM
hondaZvic's Avatar
great!!! ya, lets see them pix.
Old Nov 13, 2003 | 01:17 PM
AL ASPIRATED's Avatar
did u add the IAB (secondary butterfly)?
if u did, how did u add da wires? i noe one wire has to go to the ecu, but what about the other? THANKS
Old Nov 13, 2003 | 04:30 PM
chero112's Avatar
Default Re: (JDMTyPeRHaTcH)
adding the wire was a little tricky because on the sheet I was using said that the secondary intake solenoids wire was Pink/blue and I couldn't find it, it's not really pink it looks red and it's behind the manifold. I just tap a wire to that one and then pined it to the ECU using a different wire.....
jordan2305
Oct 20, 2008 04:40 PM
red-si-eg..
Mar 31, 2008 09:48 PM
Freeltec
Jun 1, 2004 05:09 PM
Cynical 1
Sep 23, 2002 04:41 PM
