Wired in IAB/KS: Throws CEL
Old Nov 17, 2010 | 05:12 PM
rhymeshark916's Avatar
Default Wired in IAB/KS: Throws CEL
I have a 95 b18c1 with the cx engine harness in a 92 vx shell. I wired both sensors directly to the ecu and it's throwing code 23 but not IAB. How do I know if I even wired IAB correctly or even working properly? Any ideas? I searched but don't really see swaps w/o using a gsr engine harness. I need help fast because I need to pass bar/referee/smog.
Old Nov 17, 2010 | 05:13 PM
Default Re: Wired in IAB/KS: Throws CEL
Old Nov 17, 2010 | 08:58 PM
BigBlock22's Avatar
you need to get you a wiring diagram for the b18c1 engine harness. having the correct wiring schematic is the best solution.the IAB should open up around 4000 rpm. you will see the lever move if all is working properly. as for the knock sensor, if the cx harness does not come with a knock sensor wire you cannot just use any wire. i believe its a shielded wire, that is probably why its throwing the code. could also be a faulty sensor
Old Nov 17, 2010 | 10:04 PM
89LSED's Avatar
YO, Hit up Crx Si-r.
He is a sac town boy as well. He is the guy that built the harness for my hatch.
he knows alot of the wiring stuff by heart!
Old Nov 18, 2010 | 01:28 AM
HondaPartsHero's Avatar
Technical Hero
Did you wire it like this:
Old Nov 18, 2010 | 04:00 PM
I'm only throwing code 23 and IAB isn't wired, weird. Maybe I need to a use different ecu. Well, yes that's how I wired D3(blue/yellow striped),cut not spliced. On the IAB, pink go to A17 and the other just splice into A20 since there is a wire present(red)? O2 sensor & Vtec, I ran into the shock towers since it was pre-wired.
Old Nov 18, 2010 | 04:03 PM
Yup "89lsed", thanks. His avatar name?
Old Nov 18, 2010 | 04:06 PM
Oh yeah, it is a brand new Omni KS.
Old Nov 18, 2010 | 07:39 PM
BigBlock22's Avatar
some sensors share a common ground... you are using a gsr ecu right?
Ron454321
Aug 27, 2007 07:43 PM
EG civic
May 29, 2006 08:15 PM
. o 69 o .
Apr 19, 2004 04:26 PM
Lei Siew Long
Jul 12, 2003 11:05 AM
