will engine work without charcoal canister hooked up
Old Dec 29, 2003 | 03:57 PM
EGhybridHB's Avatar
Default will engine work without charcoal canister hooked up
will engine work without charcoal canister hooked up on 94 ls motor, this is for a motor swap that has not been done yet. reason i ask is because i have a 96 ls intake manifold and it not the same hose routing as the 94 ls
thanks
Old Dec 29, 2003 | 09:30 PM
Hybrid96EK's Avatar
Default Re: will engine work without charcoal canister hooked up (EGhybridHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhybridHB &raquo;</TD></TR><TR><TD CLASS="quote">will engine work without charcoal canister hooked up on 94 ls motor, this is for a motor swap that has not been done yet. reason i ask is because i have a 96 ls intake manifold and it not the same hose routing as the 94 ls
thanks</TD></TR></TABLE>
Yes, it will run just fine. Its just emissions garbage.
Old Dec 30, 2003 | 05:26 PM
EGhybridHB's Avatar
Default Re: will engine work without charcoal canister hooked up (Hybrid93Eg)
thanks for the reply.
This system is responsible for the recirculating the gas tank vapors to the intake. also this is part of the EVAP system. this motor will not be smogged as i will throw in the stock cx motor for that.
Old Dec 30, 2003 | 05:41 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhybridHB &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the reply.
This system is responsible for the recirculating the gas tank vapors to the intake. also this is part of the EVAP system. this motor will not be smogged as i will throw in the stock cx motor for that.</TD></TR></TABLE>
Why not just smog the engine? Ref it and be done with it.
Old Jan 1, 2004 | 10:46 AM
EGhybridHB's Avatar
i plan on enternal work and a vtec head later, for sure i know it will not smog.
killer_Bseries
Aug 4, 2008 11:50 PM
89 pos
Sep 23, 2005 06:14 PM
JnyStylz
12
Dec 28, 2004 10:48 AM
WhoNeedsBoost
Apr 24, 2002 10:29 AM
