What Pistons????????
Old Oct 4, 2001 | 04:21 PM
BoostinDC2's Avatar
Default What Pistons????????
im building a LS/Vtec and im going to run a direct port NOS kit on it. i was wondering what oem piston i should use i was thinking USDM ITR piston.
Old Oct 4, 2001 | 09:43 PM
Blown90hatcH's Avatar
Default Re: What Pistons???????? (BoostinDC2)
That will yield a nice high compression...I think that it is around 10.8:1
Old Oct 5, 2001 | 12:17 AM
B18C-EJ1
Guest
Posts: n/a
It all depends on how much nitrous you want to squeeze. I'd invest in a good set of forged pistons. OEM's are nice, but they don't mix well with large amounts of the juice.
Old Oct 5, 2001 | 02:10 AM
paulzy's Avatar
Default Re: What Pistons???????? (B18C-EJ1)
just get some SRP's. Cheap and better than stock
Old Oct 5, 2001 | 07:06 AM
WAFFLES's Avatar
Default Re: What Pistons???????? (Slow_ass_4dr)
If you want OEM, use either GSR or LS in your LS/VTEC, just be careful not to squeeze to much juice. If your going with a lot of juice switch to after market slugs.
Old Oct 5, 2001 | 10:23 AM
BoostinDC2's Avatar
Default Re: What Pistons???????? (WAFFLES)
how much cheaper are SRP's compared to JE's
Old Oct 5, 2001 | 12:46 PM
EVOCELICA's Avatar
New User
SRP's are crap don't waste your money just buy a good set of JE's and also get some crower rods. That right there will easily hold a 100 shot direct port with the right config
Old Oct 6, 2001 | 10:14 AM
Jared's Avatar
Default Re: What Pistons???????? (EVOCELICA)
SRPs are not crap, they are good pistons, but wont stand abuse from detonation as readily. Don't give stuff a bad reputation just because you heard this or that.
Old Oct 6, 2001 | 11:05 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: What Pistons???????? (Jared)
Acutally SRP's are not made for NOS or Turbo. I've seen many problems with them and they don't respond well to FI.
All motor they are fine, but JE's are better, Wiseco's are even better than JE.
Old Oct 7, 2001 | 11:43 AM
EVOCELICA's Avatar
New User
I know SRP's are crap not from hearing this or that I know from experiance. I have crack several of them from light nitrous use. Don't waste your money, for an lsvtec you should use ITR's they will make you good solid power for an all motor app. For nitrous I would use JE's
[Modified by EVOCELICA, 8:44 PM 10/7/2001]
Old Oct 8, 2001 | 04:28 AM
CRX_VTEC's Avatar
Wiesco arent as nice as JE. IMO JE are the best and most durable. Wiesco are nice.. dont get me wrong but I've inspected and installed plenty of them along with Arias.. and neither are as nice as JE. My 2 cents..
queda
12
Nov 1, 2007 10:05 PM
wfocrx
Feb 4, 2007 08:10 PM
92integra-R
Jan 17, 2007 01:52 PM
six7one
May 30, 2005 01:26 PM
blueskiesfade609
Nov 14, 2003 12:09 PM
