What OBD is this engine?
Old Apr 8, 2004 | 08:05 PM
Ej6B20's Avatar
Default What OBD is this engine?
Modified by Ej6B20 at 12:43 AM 4/9/2004
Old Apr 8, 2004 | 08:33 PM
EP3_05's Avatar
Default Re: What OBD is this engine? (Ej6B20)
Large pics but it looks to be an OBD0 b16a
Old Apr 8, 2004 | 08:44 PM
Ej6B20's Avatar
Default Re: What OBD is this engine? (91civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">Large pics but it looks to be an OBD0 b16a</TD></TR></TABLE>
Resized.. damn, I should have trusted myself instead of listening to the guy who sold it to me.
Turbogixxer's Avatar
the white plugs give it away
Old Apr 8, 2004 | 10:05 PM
Default Re: What OBD is this engine? (turbogixxer)
Sorry I can not reply to PMs
my computer is still messed up
OBD zero are white (clearish) plugs
OBD one are grey plugs with grey injector clips
OBD two are grey plugs with black injector clips
Also that is a one million series motor (the numbers on the bottom of the engine code| it starts with one so it would be a one million series) which makes it a eighty nine to ninety three motor
OBD zero uses different sensors to tell the computer where the motor is
You can put a OBD one|two dizzy on the motor and it will work
The ECT sensor is also on the block on OBD zero motors (You will have to rewire it because OBD one|two ECT sensors are on the thermostat housing)
Old Apr 9, 2004 | 04:28 AM
VTECVillain's Avatar
Engines aren't technically classified as OBD, rather their electronics and certain parts is what sets them apart. The white plugs on the engine harness and the vacuum port on the manifold would classify that as an OBD0 first gen B16A.
Old Apr 9, 2004 | 05:00 AM
vtec69's Avatar
Default Re: What OBD is this engine? (VTECVillain)
i would have said obd1 until i saw the white plugs
defenitly OBD 0
-Brian
Old Apr 9, 2004 | 10:16 AM
Ej6B20's Avatar
Default Re: What OBD is this engine? (vtec69)
In order to convert it to OBD1 I would just need to change the dizzy and rewire the ECT sensor to the thermostat housing?
Old Apr 9, 2004 | 10:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6B20 &raquo;</TD></TR><TR><TD CLASS="quote">In order to convert it to OBD1 I would just need to change the dizzy and rewire the ECT sensor to the thermostat housing?</TD></TR></TABLE>
yes
Old Apr 9, 2004 | 09:12 PM
Combustion Contraption's Avatar
obd0
Mr.Chow
May 12, 2008 01:57 PM
xtokex
Oct 6, 2007 05:05 AM
MUGEN_B16CIVIC
Jan 30, 2004 01:07 PM
EK_FERIO
Nov 25, 2003 04:10 PM
jetpilot
11
Oct 26, 2003 03:42 AM
