what ecu
Old Jul 17, 2004 | 07:47 PM
integr8er's Avatar
Default what ecu
wich ecu do i need to pass obd2 diag for emissions. i have 97 hatch with h22a. i am running p13 and is the transformation to obd2 difficult ,will i lose power?is it possible to pass and switch back to obd1? i dunno im getting lost my self sorry
Old Jul 18, 2004 | 12:30 AM
eg_type_r93's Avatar
Default Re: what ecu (integr8er)
i belive what a conversion harness does is let you use obd2 wiring harness/ distributor/ alternator and use an obd1 ecu correct me if im wrong?
if this is true geta obd2 a prelude vtec ecu isn p13 obd1? 93 up vtec prelude
Old Jul 18, 2004 | 02:34 PM
integr8er's Avatar
Default Re: what ecu (eg_type_r93)
doesnt obd2 have two o2 sensors ? how do u get around that
Old Jul 20, 2004 | 04:10 AM
93H22ACX's Avatar
you will need the OBD-II ecu from the 97-up preludes. how did you wire up your obd-I P13 to work with your obd-II car?
what engine harness did you use?
Old Jul 21, 2004 | 09:03 PM
integr8er's Avatar
Default Re: what ecu (93H22ACX)
stock harness with obd1 adapter harness and then ran the extra wires needed
StraussBuster
Sep 18, 2013 11:32 AM
Rok_Stok
Oct 22, 2010 03:04 PM
97DGreenEx
Oct 13, 2006 06:21 PM
PUSHER
May 9, 2003 10:20 PM
Gmedalion
Jul 10, 2002 07:56 AM
