weird vtec problem???
Old Jul 23, 2002 | 10:56 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default weird vtec problem???
it's a ls/vtec and i just got a jdm p30 yesterday to wire the necessary sensors and switches. when i re-attatched the battery and started up i got code 22 (pressure switch). that was the only code...i let it warm and proceeded to test drive anyway. i ran up and through 1st gear slowly as i usually do to feel and hear the cam switch. well though i had a pressure switch code, it DID cam. oh yeah, the motor is boosted 8psi. no problems with detonation. ignoring the check light, it drove strong as hell. so i went back to check out the pressure switch thing and, to make a long story short, it turns out that it was pinned to d5(empty) and not d6 where it was supposed to be at. i switched it and cleared the code. started back up with no cel. took it for another drive and same 1st gear climb to check for the camming effect, but this time there was no tug then the rpm didn't blast up like normal? it seems like it's just as fast but there is no obvious crossover? i have let numerous people drive and ride to see if they can tell a switch. they can't tell and most people think it's not switching. i kinda think it is though i can't hear it. it's like there's a 2nd turbo spooling up and there is a lot of power past 6k unlike before when i was only riding aroung with just the low cam. any input or advise? thanks.
Swap'DShuttle
10
Aug 12, 2012 02:35 AM
hondaswap
Engine Management and Tuning
14
Jul 21, 2009 09:21 AM
Dekorum
13
Mar 21, 2009 10:08 PM
hondaeg8
May 3, 2004 10:15 AM
Blake97GSR
Nov 7, 2003 06:01 AM
