vx wiring question
You car is pre wired with everything you need. See the instrictions in my sig. Don't worry about the secondary intake runner part. You don't have them.
As long as the motor and all the components on it are OBD1 then I would reuse your stock VX engine harness. If it's OBD2, like as in a 99-00 Si B16A2 with all OBD2 components then I would get a USDM OBD2 GSR/ITR harness. This will eliminate the need to change the injector clips, and the distributor and alternator plugs.
