VTEC GROUND QUESTION
What??????
The vtec solenoid has one wire that runs from the solenoid to the ecu.
The vtec oil pressure switch has one wire that runs to the ground on the thermostat housing and one wire that runs to the ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVAN93EG »</TD></TR><TR><TD CLASS="quote">thanks. i wasnt sure where the wire grounded or if it needed a 1 volt ground.i know some of the ecu pins are 1 volt grounds and wasnt sure if vtec ran off one. </TD></TR></TABLE>
What's this about??
What's this about??
