VSS questions
Old Sep 7, 2001 | 03:24 AM
solorexer's Avatar
Default VSS questions
I recently swapped a JDM siR gauge cluster into my 90CRX. I am using a D16 engine and tranny and have the electronic VSS from a 92 Civic to use with the cluster. (the stock setup is a mechanical VSS) Is there anyone here with the knowledge to guide me through the wiring of the electronic VSS? There are three connections to be made to the VSS (I believe 1-pos, 1-neg, 1-signal).
Old Sep 7, 2001 | 08:16 AM
RyanR's Avatar
Default Re: VSS questions (solorexer)
The middle wire on the VSS is the speed signal, run that wire up to the cluster. The black wire on the outside is ground and the other outside wire is a power source.
Old Sep 7, 2001 | 11:58 AM
solorexer's Avatar
Default Re: VSS questions (97TypeR_9)
I only ave the sensor, no harness to go with it. which outside is ground? there is a flat side and a peaked side on the VSS. Viewed wih the flat side toward you, is the ground on the left or the right?
Old Sep 7, 2001 | 12:09 PM
RyanR's Avatar
Not sure, I'll have to check tonight and get back to you.
2000CivicEK
11
Jun 18, 2009 05:50 PM
Turbo Dan
20
Aug 5, 2008 09:46 PM
EF8IGHT
Feb 14, 2006 09:11 AM
c for sea
13
Apr 9, 2004 04:41 PM
