uh oh?!?!?!
i finished the swap over a month ago.. everything was working good.. cruise was working.. and horn.. and no check engine lights were coming on... then last week i noticed my cruise was not working for some reason?.... then a couple days later my SRS light came on.. hmm?.. (im wondering whats going on?) then the next day.. my horn wont work.... ***WHAT IS THE DEAL WITH MY STEERING WHEEL*** is it the steering wheel.. i took it off to make sure everything was plugged up.. it is... but the SRS light is still on. so i went and disconnected both air bags, dont want those things blowing up in my face on the street.. that would suk... anyone have an idea? i checked the fuses.. all are good. and when hooked up.. the light is still on and nothing works.. im lost on this one.... any help would be great.
thanks
thanks
the plug underneath the dash ono the passenger side to check the engine light codes might have a wire in it. check to see if there's a wire sticking out of it or not. this causes the SRS light to come on.
good luck,
--justin
good luck,
--justin
take off the kick panel below the glovebox and there should be a little two prong plug. check if there's any wire sticking out of it that may be the cause of the SRS light. PM me if you need more detail
--justin
--justin
ToxicBug
23
Oct 22, 2005 01:23 PM
mikehawkBUiLT
31
Oct 6, 2004 11:24 AM
