SRS light on!
SRS light on!
As said my SRS light came on one day after I installed my intake Any possiable relation. I know that it is the Air bags and that it must of failed the test(at starting)
but would the intake do it? I doubt it but I need help.
1997 Civic EX Sedan
J
1997 Civic EX Sedan
J
GDD Member
Re: SRS light on! (shermanyang)
Check the fuse. My SRS light is on all the time because I replaced the steering wheel with aftermarket and was too lazy to take out the SRS unit under the dash. Before replacing my wheel, I had the light on and I just changed the fuse and it went away.
Re: SRS light on! (slomofo)
Re: SRS light on! (civil97ex)
try to dissconnect the battery for about 30 sec. and it may go away..my check engine light was on after i installed mine in my Si then it went off.
Re: SRS light on! (low93ex)
Eeeek.... The SRS light came on for like a millisecond in my mom's Accord V6 when she braked hard. Should I worry about that?
Re: SRS light on! (dom93hatch)
it happens in v6 accords a lot.. my friend has a v6 2002 4 door LX accord. it turns on whenever she brakes hard or turns hard.. its because it has side impact air bags and when ur arm hits it or something hard enough it will flash or blink.. she has that problem.. but i have a question to u all.. i pulled out my srs fuse to see whats up with it.. started the car and then drove for a while(20 mins) then i put the fuse back in and the light remains on.. it was fine till i pulled it off.. i know its just needing to be resetted but how?
PDXHatchback
03-23-2003 06:32 PM
