Which two wires to switch if TPS is reading reverse?!?
Old Nov 17, 2003 | 04:29 PM
Jason kiDD's Avatar
Default Which two wires to switch if TPS is reading reverse?!?
Now I finally hooked up the VAFC sunday and noticed that my throttle is reading 100% at idle and goes negative when I step on the gas..
lol
I dont wanna have to guess and I am lazy to find a book right now, but my guess is that is why the stock p28 is running so well with it now..
Old Nov 17, 2003 | 06:31 PM
VTECVillain's Avatar
Default Re: Which two wires to switch if TPS is reading reverse?!? (Jason kiDD)
Whenever you do a DPFI to MPFI in the EF's you switch the 2 outer wires to reverse the polarity. It sounds to me like you hooked the VAFC up wrong for the TPS wiring part.
Old Nov 17, 2003 | 06:47 PM
Jason kiDD's Avatar
Default Re: Which two wires to switch if TPS is reading reverse?!? (VTECVillain)
No actually I ended up switching the wires one time by accident because I thought it was causing the car to shut off. So that is what I will do. Switch the 2 outer wires and see what happens then..
95ludeSE_bottle
Jan 13, 2009 06:44 AM
x_tuh_sy
Audio / Security / Video
Dec 20, 2007 05:35 PM
b00sted4dr
Aug 3, 2006 10:27 AM
2+2Door
Jul 21, 2004 10:19 PM
