tranny problem
Old Sep 4, 2003 | 08:39 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
Default tranny problem
95 b16a in 92 hatch with itr tranny. its having a problem going into second gear. it feels like a wall or a barrier not allowing me to put the car in 2nd. every now and then it lets me but rarely. what could be the problem?
Old Sep 4, 2003 | 08:41 PM
zelifcam's Avatar
Default Re: tranny problem (ruthlessbucket)
Aside from the shift forks being damaged or other internal transmission damaged, check your shift linkages... have someone shift it around while you're under the car and make sure they aren't binding on anything, and that the shift rod is going into the transmission at the proper angle... my entire engine is tweaked on it's mounts due to my ghettoing a D16Z6 engine mount with a bunch of washers, and someones i have problems getting into reverse and 3rd...
Old Sep 4, 2003 | 09:00 PM
jumpmann23's Avatar
Default Re: tranny problem (zelifcam)
so it could b the linkage? could it be the syncros? all the other gears work perfectly but 2nd
Old Sep 4, 2003 | 09:06 PM
zelifcam's Avatar
Did this problem just happen or has it existed since you built the hybrid? Also, what shift rods are you using?
Wheelman-CZ
Jun 8, 2006 05:10 PM
AgentofDarkness
Jun 3, 2006 07:47 AM
sohc prelude
Feb 26, 2006 07:26 PM
teamvirus
Dec 12, 2005 09:51 PM
boomslang
Nov 18, 2001 12:00 AM
