Timing Belt
Old Aug 27, 2005 | 06:59 AM
93preludeh22's Avatar
Default Timing Belt
Is it worth the extra money buying the Timing Belt and Water Pump OEM?
I can get manager discount at a Kunkel's store... not oem but still good stuff
What do you guys think?
Anthony
Old Aug 27, 2005 | 01:11 PM
Default Re: Timing Belt (93preludeh22)
bumpity bump bump bump
Old Aug 27, 2005 | 01:23 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">Is it worth the extra money buying the Timing Belt and Water Pump OEM?</TD></TR></TABLE>
What brands does that store carry?
Old Aug 27, 2005 | 01:56 PM
Lord Helmet's Avatar
On such a crucial area on the engine why not pay a little bit more. I'd never use non-OEM parts when it comes to the water pump and timing belt. Pay a little now or pay ALOT later. Your choice.
Old Aug 27, 2005 | 04:34 PM
slomofo's Avatar
GDD Member
Default Re: Timing Belt (Lord Helmet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet &raquo;</TD></TR><TR><TD CLASS="quote">On such a crucial area on the engine why not pay a little bit more. I'd never use non-OEM parts when it comes to the water pump and timing belt. Pay a little now or pay ALOT later. Your choice. </TD></TR></TABLE>
What if it were a spoon belt and a meziere pump? OEM guys make me sick, I don't run OEM belt/pump... do you run an OEM air filter?
Old Aug 27, 2005 | 06:03 PM
Default Re: Timing Belt (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">
What if it were a spoon belt and a meziere pump? OEM guys make me sick, I don't run OEM belt/pump... do you run an OEM air filter?</TD></TR></TABLE>
Guys who run spoon belt and a meziere pump makes me laugh, I don't waste my money for the name and hype. Those parts are for "RACING ONLY" not for the typcial daily driver. BTW yes I run the OEM air filter.
Old Aug 28, 2005 | 03:03 AM
gixxer, I'll find out and let you know.
I'll let you know on monday
Old Aug 28, 2005 | 03:05 AM
I think they sell Gates belts
WATER PUMPS:
A1-Rebuilt
Airtex
Old Aug 28, 2005 | 08:03 AM
Default Re: (93preludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">I think they sell Gates belts</TD></TR></TABLE>
Gates belts are great. I have installed many of them and never had a problem. I do not know about the water pump(s) you said, I have never used them.
Old Aug 28, 2005 | 10:36 AM
Alight, thanks
I'll buy them from Kunkels (considering I get like half off list price) and try them out. Any problems I'll let you guys know!
Old Aug 28, 2005 | 03:17 PM
JeffBro's Avatar
Default Re: (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
I heard mixed things about Gates for timing belts. A good friend of mine who has been working on hondas for 15 years says on Gates... Try Oem. The oem belt is like 60 dollars but worth it...
Old Aug 28, 2005 | 03:44 PM
slomofo's Avatar
GDD Member
I'm running an OEM pump and a gatorback belt, not OEM, but does it really matter?
Can somebody prove the negative effects of a non-oem belt?
Anyone have an actual time lapsed test showing the wear and tear of OEM vs Aftermarket Timing belts/waterpumps?
Goodyear has been around longer than Honda, Goodyear specializes in the rubber field, belts are made of rubber, honda makes engines not rubber, I think it's safe to say that Gatorback is better than OEM.
Does anyone know the name of the company that makes belts for Honda?
Old Aug 28, 2005 | 04:14 PM
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know the name of the company that makes belts for Honda? </TD></TR></TABLE>
It is Gates and Banjo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Goodyear has been around longer than Honda, Goodyear specializes in the rubber field, belts are made of rubber, honda makes engines not rubber, I think it's safe to say that Gatorback is better than OEM. </TD></TR></TABLE>
That does not mean they are made of quality. I have replace many broken goodyear belts. Not saying that it will break on you, but I have seen it too many times. There drive belts make noise more then other brands. Thats if what I have seen.
Old Aug 29, 2005 | 04:06 PM
hgtwamp095's Avatar
im a honda mechanic for a dealer. ive seen aftermarket belts and pumps go bad early. it is way worth the money. and if you can afford the money to have it installed it will save your *** if you or who ever messes it up.
globy123
Jul 25, 2008 05:02 PM
dohcredsol
Mar 25, 2008 10:13 PM
lv6l
10
Oct 13, 2005 07:27 AM
crizkeeth
Dec 27, 2004 10:50 AM
hatchman12
May 12, 2004 08:12 PM
