Throwing code help please
So in the process of trying to get my swap to run ( b18b in a crx si ) it cranks but wont start . i'm throwing a code 8 wich is apparently TDC/crank sensor so i read , any suggestions on how to fix this ? or ideas on how to troubleshoot this ?
does anyone have a wiring diagram of the b18b distributer side ? because my distributer came with square plugs but my harness uses circle plugs , so we took the square plugs off and put the circle ones on to make it plug and play and did what we thought was the correct wiring.... guess not
rustbucketrex
Jun 28, 2007 06:43 AM
