what do i need for a engine swap ...93 (cable tranny) integra ls going in 94 civic
what all do i need for a engine swap ...93 (cable tranny) integra ls going in 94 civic
i know wiring harness is the same what else will i need.also what is the conversion kit i need for tranny..
Re: what all do i need for a engine swap ...93 (cable tranny) integra ls going in 94 civic (import_r
you need the the hasport trans mount kit, it also includes the hydro to cable bracket to use the hydro setup to the cable trans. 94 up integra rear mount bracked.shift linkage and driverside mount and bracket on the block you can use the older axles you have to use the obd1 ecu for whatever engine you are using. you also need the b series throttle cable 92 up integra.you have to change the speed sensor on the trans from the cable style to the electric one. you can use your factory one out of your d-series trans.just unbolt it and slide it out.you also use your factory wire harness you may have to extend some plugs as necessary.
Maleek
01-03-2010 03:44 AM
TwoPointZero
10-02-2004 08:25 AM
