swapping to better mounts
Old Nov 10, 2005 | 06:04 PM
92 CIVIC HATCH VX's Avatar
Default swapping to better mounts
i got a h22 swap in my eg hatch.i think they are avid mount in there now, i bought some hasport mount and i start removing the mounts and installing the hasport. but the problem is that when i start the mounts they where off and the engine need to be moved forward to work with the hasport mounts.is that normal? If so how can i move the engine forward. i put a jack under it to hold it up, do i need to remove all mounts and move the engine forward or can i remove the side mounts and it will move?
i'm kinda confused...
Old Nov 11, 2005 | 09:38 AM
Default Re: swapping to better mounts (92 CIVIC HATCH VX)
bump
Old Nov 11, 2005 | 10:28 AM
jdmcars.com's Avatar
You are replacing all the mounts with the HaSport mounts, correct?
The HaSport mounts normally will place the engine in a different location in the engine bay, and it would normally require you to replace all the mounts. If that is the case, the easiest way to do so would be to support the enngine so that you can still move it around in the engine compartent (cherry picker) and then re-install all the mounts.
GoLowDrew
Jun 25, 2013 08:34 AM
EG6Boy702
33
Apr 27, 2009 03:55 PM
sixtodc2
Jul 13, 2007 12:43 PM
LbcJiGGa
Feb 24, 2003 07:17 PM
01gizzer
May 30, 2002 11:56 PM
