Swap Question
Old Mar 1, 2003 | 04:27 AM
Mann000's Avatar
Default Swap Question
I have a 93 Dx. I just got a 99 Ls swap without a engine harness. What harness should I get? Thanks
Old Mar 1, 2003 | 03:26 PM
Sohc Driver's Avatar
Default Re: Swap Question (Mann000)
Are you using the 99 LS ECU? If so...try to get the 99 engine harness, 99 civic chassis harness and plug it up to your 99 ECU
or
get a 93 integra engine harness, plug it up to your current harness, and get a 93 integra b18b ecu and plug it up to your current harness...
or
get a 93 integra engine harness, plug it up to your current harness, keep the 99 ecu and plug it up to your current harness with the 0bdi-->obdii(99-01) jumper harness conversion
Khoi
[Modified by Sohc Driver, 6:27 PM 3/1/2003]
[Modified by Sohc Driver, 6:28 PM 3/1/2003]
Old Mar 1, 2003 | 03:43 PM
Mann000's Avatar
Default Re: Swap Question (Sohc Driver)
Some guy got a 95 ls harness I can get. Then I'll will sell my 99 ecu to get a obd1 ecu. Would that work?
Old Mar 1, 2003 | 03:50 PM
hondaeg5's Avatar
yes
Old Mar 1, 2003 | 03:51 PM
yes that will work, get the 95 LS engine harness and plug it to your 93 chassis harness(plug and play).. and the obdi ecu should plug up to your current harness.
Khoi
[Modified by Sohc Driver, 6:53 PM 3/1/2003]
Old Mar 1, 2003 | 03:59 PM
Mann000's Avatar
Hey thanks I've been tryin to get that answer for a couple days now.
just_dung
11
Jan 7, 2013 11:42 PM
jm2000turbo
Mar 29, 2012 07:00 AM
da59block
14
Nov 11, 2011 12:33 PM
mrjenkins
Jul 4, 2008 01:03 PM
teefunk01
Mar 29, 2005 07:09 PM
