swap question
Old Nov 19, 2006 | 07:55 PM
Ha Itz's Avatar
Default swap question
i am putting a obd2 ls into my 97 civic coup and i was woundering if i can use the stock mounts with the exception of the si rear bracket.. i searched but im getting mixed reply on some saying i need aftermakret mounts and others saying i can use the stock so im just checking this from you guys...thanks
Old Nov 20, 2006 | 06:06 PM
Katman's Avatar
Default Re: swap question (Ha Itz a Jew)
No need for aftermarket mounts for this swap.
you can reuse all of your existing SOHC rubber engine mounts, but you cannot reuse all of your existing SOHC brackets. The only brackets you can reuse is your TOP TRANNY MOUNT and the timing belt side bracket & mount. Everything else needs to be from a 99+ Si ie. front tranny bracket, A/C bracket, rear engine bracket.
If your LS motor comes with axles, shift linkage, any of hte brackets listed above (except rear engine bracket) you can use them all for your swap.
curioso
Nov 12, 2009 08:23 PM
88 EF Hatch
11
May 13, 2009 10:39 AM
hspoon
Feb 21, 2007 08:43 AM
Youlose1305
May 21, 2006 08:09 PM
Youlose1305
May 18, 2006 06:36 PM
