Specific Eagle rods for ls/vtec
Old Aug 6, 2003 | 07:05 PM
notsure's Avatar
Default Specific Eagle rods for ls/vtec
i have an ls/vtec (b18b/gsr head) i am buying some eagle rods, and i dont know which ones will fit in my car. there is a set for b18 a/b non vtec, this is what i thought i should buy, then there was a set for a b18b vtec. anyinput would be appreciated. here is the link http://www.cdpautomachine.com/....html
Old Aug 6, 2003 | 08:18 PM
thid92's Avatar
can I haz?
your good to go
Old Aug 6, 2003 | 09:38 PM
Newman's Avatar
New User
Default Re: Specific Eagle rods for ls/vtec (notsure)
The differences are in the area where the piston is pressed onto the rod. Some of the rods are already shaved to accomodate a different VTEC piston (like a PCT CTR piston or PR3/P30 SiR piston) so it all depends on what piston you plan to use. Otherwise, the length are the same, and you need to use the LS rod length if you use the LS crank, otherwise it won't work.
EGcivicvtec
21
Jan 11, 2006 05:29 PM
Yellb16crxsi
May 19, 2003 12:19 PM
shilohcrx
Dec 15, 2002 10:25 AM
BuddhaSiR
Dec 6, 2001 05:21 AM
