sohc zc vtec
simple question: what does this motor closely resemble? the d16z6 or the d16y8, i want to buy a cam and a few other things, and i want to know what parts i should buy, either the y8 parts or the z6? thanks for your help!
Screw you guys, I'm... going... home.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 »</TD></TR><TR><TD CLASS="quote">i thought a ZC was an old DOHC VTEC?</TD></TR></TABLE>
I have heard that there are three basic kinds of ZC, and like his topic title states, he is talking about the sohc vtec one. btw I thought that there wasn't a dohc vtec zc! Anyone got any good links that explain ALL the different zc engine families? And before you say "USE THE SEARCH!!!" you can't search for two letter words like "zc" on this board.
This is copied from a page I found a long time ago. I can't remember the URL or who did the write-up:
"The ZC engine comes with an engine block that has 4 cylinders, water-cooled, with bore and stroke as 75mm by 90mm, ie an undersquare design. Thus, the capacity of the ZC engine is always 1590cc. The ZC engine comes in various configurations, SOHC, DOHC, carbaretted as well as fuel-injected. The only configuration that ZC does not come in is in DOHC-VTEC form. The ZC engine is also used in a large variety of models. The list below tries to tie the various configuration of the ZC engine to examples of Honda models and types that they appear in. This list is not intended to be exhaustive."
SOHC twin-carburetted
16V SOHC, with dual Keihin carbs mounted side-ways.
Max Power : 105ps.
DA-series Honda Integra RX and ZX.
DC-series Honda Integra ZX.
EG-series Honda Ferio RTX (EH1) with 'realtime' 4WD.
SOHC PGM-Fi
16V SOHC, Programmed Fuel Injection.
Max Power : 120ps.
EF-series Honda Civic 36i (4door).
DA-series Honda Integra RXi and ZXi.
DB/DC-series Honda Integra ZXi.
Revised DB/DC-series Honda Integra, various models, eg Ti, Xi-G, Xi(4WD).
SOHC VTEC PGM-Fi
16V SOHC with VTEC, Programmed Fuel Injection.
Max Power : 130ps.
EG-series Honda Civic Ferio EXi (coded as E-EJ3).
DOHC PGM-Fi (First generation)
16V DOHC, Programmed Fuel Injection.
Max Power : 125ps.
1st Generation Honda Civic Si.
1st Generation Honda (coded as E-AS) CRX Si.
1st generation Honda 'Quint' Integra GSi and RSi.
DOHC PGM-Fi (Second generation)
Max Power : 130ps.
EF-series Honda Civic (4door and 3door) Si.
EF-series Honda CRX Si (EF7).
EG-series Honda Civic Ferio RTSi (EH1) with 'realtime' 4WD.
The ZC engine also appears in other Honda lines, notably in SOHC PGM-Fi and SOHC Dual-Carb'ed form in the Concerto line-up which was also available for export (Singapore is one country which has this model in its domestic lineup).
Max Power : 105ps.
SOHC PGM-Fi
Max Power : 120ps.
SOHC VTEC PGM-Fi
Max Power : 130ps.
Max Power : 125ps.
Max Power : 130ps.
Theres such a thing as a ZC SOHC VTEC engine. My boy got one in his EF hatch. The engine code just says ZC, and the valve cover says VTEC and has a VTEC solenoid. So guess what...ahahahaa.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECHB »</TD></TR><TR><TD CLASS="quote">Theres such a thing as a ZC SOHC VTEC engine.</TD></TR></TABLE>
Where did anyone say that there wasn't one?
