ecu
ecu
i have my z6 head and im goin to put it in my d16a6 block. i have the intake manifold vtec solenoid ect... but do i need a ecu from a 92-5 civic, or can i use the ecu on my 1990 civic si??
Re: ecu (krazeemidget)
if you want to run a P28 ECU (92-5 si/ex sohc vtec ECU) then you'll need to rewire dizzy (run OBDI) other changes/rewiring is the ECU plugs to 92-5 style plugs. easier way is to simply buy the non-obd to OBDI harness converter and add the proper wires.
if you want to run your PM6 ECU (88-91 Civic/CRX Si), you need an external vtec switch such as vtec controller, relay or shift light activation. also the fuel maps/ignition/rev limit is not really well suited for a sohc vtec motor
my suggestion is to run the harness converter change around the wiring and go with the P28 ECU.
