secondary o2 sensor question...
I have a 97 LS motor in my 92 civic hatch with a 95 LS ECU (p75). I know obd2 motors have a secondary o2 sensor. but I don't have one because...
1) my swap didn't come one
2)I have no wiring for it
do I need to hook a secondary o2 sensor up somehow? or since I have the obd1 ecu, don't even worry about it.
I'm not getting any check engine lights, but when I jump the ecu it gives me a code 2. which is secondary o2 sensor
i'm running a turbo on the motor so I wanna make sure the correct fuel is getting to the motor, so that's why I'm kinda worried.
thanks in advance...
check the code again and make sure it's a 2 and not 20
Clear the code and don't worry if your not getting a check engine light. 1995 LS is OBD1 and does not have a secondary O2 sensor. There is a code #2 for 1995 Acura's, but it is for the second O2 sensor on a Legend--the Legend uses an O2 sensor on each exhaust manifold. If you are getting two long blinks then you have a code #20 which is for the automatic transmission lock-up solenoid. If you are using an automatic ECU on a manual transmission, you will get the code #20.
oh, I see a code 20 being an electrical load detector circuit. what does that mean?
[Modified by HondaCutter, 1:25 AM 11/28/2002]
My bad, code #19 is automatic lock-up solenoid, #20 is ELD. ELD is there to check alternator output. Clear the code-if it comes back, then start troubleshooting. There may be a pinout issue using a 95 LS ECU with a 97 engine harness. I will check the ETM's for these two vehicles when I go back to work on Friday.
I have a new alternator from auto zone, so I wonder if the fact that it's an alternator from autozone has something to do with the code 20. if it is a code 20, i need to double check. or it could be the battery, I guess, it IS the same stock one from 10 years ago.
