s2k s2000 gauge cluster fully functional in an eg or ek?
#2251
Re: s2k s2000 gauge cluster fully functional in an eg or ek?
I need a little help......My cluster is working, but the ECT and Speedo Healer is not.
1. I don’t think I hooked up the Speedo healer correctly, can someone enlighten me as to what gets hooked up where?
2. My ECT seems to not take a file when I try to upload it. If I hold the reset down on the chip, the temp gauge starts going down. The second I let the button go, it starts to go back up slowly. Any ideas here would be great too.
Thanks
Thanks
#2254
Thanks
Thanks
have you tested the ect chip? does it give you wrong temp bars?
#2255
I took the ECT and Speedo Healer out due to the car running like crap with it hooked up. Car ran fine without it, so i know for sure it is hooked up wrong. Both units light up, so i know power and ground is right. I dont know for sure what pins/wires i need to wire what to on the computer side, and to cluster. I have a P28 ECU, and of course an AP1 cluster. I plan to trying this again today.
Thanks!!!
#2256
The wires for outputs where ran incorrectly. So the temp bars whre jumping from 1 bar to full bars and back. The speedo would not move from 0. I know the units whre hooked up wrong, i need to figure out what pins from the ECU get spliced into the ECT chip and healer. If anyone could help, it would be great, i tried a pinout already.....
#2258
[-VIDEO-]
S2000 Cluster :: MOV-0004.flv video by iamamericangraffiti - Photobucket
this is a guy off jdmu
#2259
#2260
Do I have to splice the white wire from the SPEEDOHEALER into the VSS sensor ,or completely cut it and wire the VSS only to the SPEEDOHEALER?
#2261
The speedohealer has 4 wires 12v+, 12v-, Vss in, Vss out. The vss has 3 wires, 12v+, 12v-, and signal. Splice the power wires together, cut the signal wire. The wire on the Vss goes to the in, the wire in the harness going to the ECU would go to the out.
#2263
so i eliminate the signal gonig to the ECU in total??
#2265
#2267
#2268
do any one have the file for the Modifry ect? I just installed mine and it will some times read full bar 1/2 bar or no bar.. dont know whats going on
I have a OBD1 b18c1
I have a OBD1 b18c1
#2269
#2270
i know this is kind off topic but its worth a shot any one that has a ap1 or ap2 cluster that has a part number on it i found a company that sells tons of connectors along with tons of other electrical parts and supplys if you have and ap1 or ap2 cluster with plugs and they have a part number printed on the plug post the part numbers here and ill see if they have the plugs and then we could have a way to get plugs if you didnt get plugs with your cluster
#2271
#2272
#2274
What up guys?
I have put a lot of input into these S2000 threads, after having a 100% functional AP1 cluster.
Now Its time for me to ask for some input.
I did my AP2 2007 cluster install and now this one has a jumping gas level guage. What type of resistor do you guys use on a Ap2 cluster in a Honda? Integra DC2 to be exact. (but im sure that all honda gas tanks are the same or very similar.)
I have tonnes of input to say on this thread regarding the 2006+ Ap2 Clusters, but, need to get mine 100% sorted first, now im just missing the gas level to be accurate.
