Running Vtec solinoid wire?
Old May 12, 2002 | 09:35 AM
InfamousRS's Avatar
Default Running Vtec solinoid wire?
Where on the OBD1 wire harness(to the ECU) is the right place to run the Vtec wire from?
Old May 14, 2002 | 03:46 PM
InfamousRS's Avatar
Default Re: Running Vtec solinoid wire? (InfamousRS)
Anyone? To The Top!
Old May 14, 2002 | 03:47 PM
Jeice's Avatar
A4
Old May 14, 2002 | 03:57 PM
InfamousRS's Avatar
Default Re: Running Vtec solinoid wire? (Jeice)
A4
How do I find A4 on the harness? Where can I get a pin for the wire at? Radio Shack?
Old May 14, 2002 | 04:33 PM
Jeice's Avatar
Old May 14, 2002 | 04:58 PM
JV's Avatar
JV
Who?
Old May 14, 2002 | 05:46 PM
InfamousRS's Avatar
Default Re: Running Vtec solinoid wire? (JV)
Thanks, thats what I was looking for.
Do I need to run 2 wires? One to the Vtec solenoind, and the other to the Vtec pressure switch?
I was under the impression that I only needed to run 1 wire.
Also, where can I get the pins for the harness?
Old May 14, 2002 | 06:56 PM
bruthaboost's Avatar
Yes, you need to run two wires. As far as the pins for the wire harness, I took a trip to the junk yard, found an old busted up harness and took the pins from it. While your there, you might as well pick up the connectors for the solenoid and pressure switch. The pressure switch will be easy to find. The solenoid may be more difficult. Just use any honda waterproof coupling if you can't find the exact solenoid coupling.
Old May 14, 2002 | 07:23 PM
InfamousRS's Avatar
Default Re: Running Vtec solinoid wire? (b18bpwr)
Where is the Vtec pressure switch located on the block?
For the Vtec solinoid, Im just going to cut the plug off, and solider and shrink wrap the 2 wires together.
stupidhard
May 15, 2014 12:33 PM
TeamRPM_ZC
Jul 14, 2008 08:36 AM
mr. carpenter
May 5, 2004 09:47 PM
lightningd
Apr 4, 2003 01:30 PM
InfamousRS
May 19, 2002 10:56 AM
