is this right??b20/vtec..tech
Old Dec 27, 2001 | 12:17 AM
just_a_sohc's Avatar
Default is this right??b20/vtec..tech
jsut completed a b20/vtec swap...check engine light comes on if i drive the car before its warmed up and would go away if i was to shut it off and turnit back on after its warm...also vtec does not kick in...oil light comes on occasioanlly for a sec or so...i was told maybe that is why my vtec isnt kickin in.....oil is at its appropritae level...so what do i do or what could i check??...tahnx all
Old Dec 27, 2001 | 06:11 AM
badCRX's Avatar
New User
Default Re: is this right??b20/vtec..tech (just_a_sohc)
Checking the engine code would be of greater insight than what most of us could tell you. I have a few friends with LS/VTEC's that have the same oil condition. VTEC won't engage until your engine coolant temp is raised where your needle will start to show a reading (basically once its budged from where it sits when its off).
Old Dec 27, 2001 | 08:24 AM
misledyouth's Avatar
New User
Default Re: is this right??b20/vtec..tech (badCRX)
it's not just lsvtec taht does this. all vtec motors won't engage vtec till the engine is warmed up. As far as the oil light i don't know. but check the code cause if the cel goes off it will still be stored in the ecu. So you can still pull the code.
jesse
Old Dec 27, 2001 | 08:52 AM
rainforest's Avatar
Default Re: is this right??b20/vtec..tech (misledyouth)
jesse is right but also vtec will not kick if youi can get 55 psi oil pressure. you could have a small oil leak but hey its prolly just the not wharming it up.
chelsea
Sep 23, 2005 01:53 PM
Cedor
Jun 4, 2005 06:51 PM
Metrocity2
Apr 27, 2005 02:03 AM
Dc4turbo408
Oct 2, 2004 01:54 AM
lilxvtecxpwr
Jan 18, 2003 08:06 PM
