removal of tps
Old Nov 28, 2002 | 08:10 AM
roc109's Avatar
Default removal of tps
does anyone have any tips on removing a tps sensor from the tb
Old Nov 28, 2002 | 08:22 AM
TREVER's Avatar
Default Re: removal of tps (roc109)
cut slots into the screws and remove with a screw driver.
Old Nov 28, 2002 | 08:23 AM
VTECVillain's Avatar
Easy.... get a dremel and use the cut-off blade to notch a straight cut across the rivet bolt head. Then use a flat tip screwdriver and loosen the bolts up.
Old Nov 28, 2002 | 11:06 AM
BuddhaSiR's Avatar
Default Re: removal of tps (VTECVillain)
you can use a hack saw to cut slots and use screwdriver.
Old Nov 28, 2002 | 12:40 PM
Kataku2K3's Avatar
Default Re: removal of tps (BuddhaSiR)
Yup Dremel is the easiest... Before i figured that out i used to use a pair of vise grips... You can clamp onto it just enough to get it loose... Dremel it
Old Nov 29, 2002 | 07:25 AM
Blaze45's Avatar
Brrraaaap!
Default Re: removal of tps (JDMspecEG6)
I busted my tps in half before I figured it out...
EX-T
Sep 2, 2008 04:33 PM
Nuke209
Dec 13, 2005 05:25 PM
aaj23
Jan 31, 2005 10:45 PM
Batoutahell
Aug 15, 2003 07:39 AM
civicracer1993
Mar 5, 2003 04:18 PM
