Quick EG Engine Swap Question
Old Jun 29, 2003 | 04:17 PM
MrEg's Avatar
Default Quick EG Engine Swap Question
did a search...found some info.........need a bit more help
Wondering...i have a B18b in my 94' EG .....going to get a 98' GSR engine....what do i have to do in order to make this work.....main concern is wiring
HARNESS??? (do i need a OBD2 > OBD 1 harness)
ECU?? (will have the 98' GSR ECU...currently have the LS ECU in my car)
anything else would really really help.....thanks tim
Old Jun 29, 2003 | 06:46 PM
JV's Avatar
JV
Who?
Default Re: Quick EG Engine Swap Question (mr_timluu)
Use the OBDII wiring harness if it comes with the GSR, it will plug into the underhood subharness. Only the EX/Si/VX trims, came prewired for VTEC in 93-95, so depending on the trim level of your civic, you may have to run the VTEC wiring to the ECU.
If for some reason it does not come equipped with the OBDII harness, you can use the OBDI LS harness. You will need to add the VTEC wiring and rewire/replace the distributor and injectors.
As far as the ECU goes. To keep the swap somewhat plug and play, you have a few choices, the simpliest being:
1. locate an OBDI P72.
or
2. rechipped P28.
If for some reason you are hell bent on using the OBDII P72, you will need an OBDI to OBDII adapter harness.
Both the rechipped P28's and adapter harnesses can be had through Kenji here on HT...
Good luck.
BTW: I'm really tired so somebody chime in if i left anything out...
Old Jun 29, 2003 | 06:51 PM
MrEg's Avatar
thank you thank you......i was really lookin for an answer soon b'c kenji'z SUMMER SALE is almost over!!!! LOL.....thanks....
aznwash3wboi
Dec 10, 2008 05:07 PM
White94Civic
Apr 18, 2008 10:42 AM
sik96teg
16
May 26, 2006 11:23 AM
ABK
May 11, 2004 03:47 PM
